Results 1 to 9 of 9
  1. Hi everyone, I write with the translator because I'm an Italian so I apologize if I'm wrong.
    is it possible to download the mpd video from this page? https://www.mediasetplay.mediaset.it/video/igrandiimperidellastoria/i-maya_F309199101000405
    When I try to analyze the manifest file, I get this link: https://vod05.msf.cdn.mediaset.net/farmunica/2019/08/434394_16c8a1006b07d2/dashrcenc/sd_wv_mpl.mpd which I think is the Manifest file.
    I tried to download the video with ffmpeg using the command: ffmpeg -i "https://vod05.msf.cdn.mediaset.net/farmunica/2019/08/434394_16c8a1006b07d2/dashrcenc/sd_wv_mpl.mpd" -codec copy prova.mp4 and this is the result:
    [Attachment 49940 - Click to enlarge]
    [Attachment 49941 - Click to enlarge]
    Then I opened the video with vlc and it gives me this:
    [Attachment 49937 - Click to enlarge]
    I decided to use the Bento4 tool to try to decrypt the mp4 file but I can't find the "Default_KID" key to decrypt the video. This is what gives me the analysis of the video "prova.mp4" using the command: mp4info --verbose prova.mp4
    [Attachment 49942 - Click to enlarge]
    [Attachment 49943 - Click to enlarge]
    File:
    major brand: isom
    minor version: 200
    compatible brand: isom
    compatible brand: iso2
    compatible brand: avc1
    compatible brand: mp41
    fast start: no
    Movie:
    duration: 3020758 ms
    time scale: 1000
    fragments: no
    Found 2 Tracks
    Track 1:
    flags: 3 ENABLED IN-MOVIE
    type: Video
    duration: 3020680 ms
    language: und
    media:
    sample count: 75405
    timescale: 12800
    duration: 38664704 (media timescale units)
    duration: 3020680 (ms)
    bitrate (computed): 1592.571 Kbps
    display width: 1024.000000
    display height: 576.000000
    frame rate (computed): 24.963
    Sample Description 0
    Bytes: 00000000000000010000000000000000000000000000000004 0002400048000000480
    00000000000000100000000000000000000000000000000000 000000000000000000000000000000
    018ffff000000366176634301640028ffe1001a67640028acd 94040049b011000000300100000030
    320f183196001000568ebecb22cfcf8f800000000107061737 00000000100000001
    Coding: avc1 (H.264)
    Width: 1024
    Height: 576
    Depth: 24
    AVC Profile: 100 (High)
    AVC Profile Compat: 0
    AVC Level: 40
    AVC NALU Length Size: 4
    AVC SPS: [67640028acd94040049b011000000300100000030320f18319 60]
    AVC PPS: [68ebecb22c]
    Codecs String: avc1.640028
    Track 2:
    type: Audio
    language: und
    media:
    sample count: 70800
    timescale: 48000
    duration: 144996352 (media timescale units)
    duration: 3020757 (ms)
    bitrate (computed): 64.001 Kbps
    Bytes: 000000000000000100000000000000000002001000000000bb 8000000000002a65736
    47300000000031c000000041440150000000000fecf0000fa0 00505131056e598060102
    Coding: mp4a (MPEG-4 Audio)
    Stream Type: Audio
    Object Type: MPEG-4 Audio
    Max Bitrate: 65231
    Avg Bitrate: 64000
    Buffer Size: 0
    Codecs String: mp4a.40.5
    MPEG-4 Audio Object Type: 2 (AAC Low Complexity)
    MPEG-4 Audio Decoder Config:
    Sampling Frequency: 24000
    Channels: 2
    Extension:
    Object Type: Spectral Band Replication
    SBR Present: yes
    PS Present: no
    Sampling Frequency: 48000
    Sample Rate: 48000
    Sample Size: 16
    Channels: 2
    Would any of you know how to help me? I would like to understand if it is possible to proceed and how to proceed. Thank you
  2. Originally Posted by LZAA View Post
    Need access.
    it is a free site and credentials can be easily created. I'm already registered. Can anything be done?
  3. Originally Posted by LZAA View Post
    Can.
    Can I send you a PM?
  4. Originally Posted by LZAA View Post
    Can.
    Can you explain me how to do it?
  5. So...what is the solution? Is it possible to download and see the video offline? Thx
